Bead roll for sheet metal
HarryJT94
HarryJT94
I am trying to create this iFeature to the pdf. I am having to offset the play to get the desired look, but I cannot seem to find out a way to get rid of the underside of the revolve. If someone could help me, it would be greatly appreciated. Thanks
Replies (14)
dgleis
What version of Inventor are you using?
dgleis
here is 2025 version
HarryJT94
Hi dgleis
2024 I believe
dgleis
You can create a sketch on the side profile of the material thickness, draw a rectangle greater then the length of the profile of the bead. Make sure rectangles top edge has a collinear constraint with bottom edge of the material. finish sketch then either cut away or extrude cut everything in the rectangle you drew.
HarryJT94
Is it allowing you to extract iFeature for sheet metal punch? That's what I am trying to do
blandb
Will this be used on rolled and flat sheets?
Autodesk Certified Professional
HarryJT94
Hi blandb,
Just on flat sheet metal
Frederick_Law
I'm on 2023, can't see features in your model.
Don't model the extra on the bottom.
Just model the finished features.
First make cutout for the feature then model the feature.
Attached my louver punch.
HarryJT94
Hi Frederick,
I can't get the desired outcome without offsetting the plane then revolving the sketch which leaves that bottom part. Won't let me extrusion cut or cut it.
Frederick_Law
Look at my louver.
Add a mirror and it might be what you want.
And it is:
HarryJT94
I will give it a go in the morning, thanks
HarryJT94
Hi @Frederick_Law, I've created it, but wont allow me to extract to a sheet metal punch iFeature
HarryJT94
See attached
HarryJT94
Anyone able to help with this?
