Tube & Pipe missing from environment tab. How do I install tube & pipe manually? I have Inventor Professional 2025 currently installed.
Solved by blandb. Go to Solution.
Solved by RajSchmidt. Go to Solution.
Solved by Gabriel_Watson. Go to Solution.
Check under tools > add-ins if the module is loaded:
You have opened a part. Tube & Pipe is only available in the assembly environment…
