Batch plot (PDF), Vault Basic, append iproperty to file name
skatzY7HV8
skatzY7HV8
I have looked around for solutions to the following problem(s): I would like to batch pdf a selection of Inventor dwgs that will be stored in Vault Basic. I would also like to be able to have this batch pdf append a dwg specific iproperty to the corresponding pdf's filename. Finally, if the initial selection of the files could utilize a search like functionality (select all files containing a certain string in the name), that would be great. Currently I am using the Task Scheduler, but that does not allow for automated file naming, and is not compatible with Vault Basic.
My questions:
Has something like this been done?
Is it possible to automate this task?
rhasell
Hi
@Curtis_W wrote an awesome piece of code.
This is the dogs bollocks of tools, and everyone should have this batch tool.
https://forums.autodesk.com/t5/inventor-forum/any-way-to-automatically-update-all-related-drawings/m...
It took me a while to get it working, but it's absolute gold.
This was the first thread, and there might be some information for you.
https://forums.autodesk.com/t5/inventor-forum/how-do-i-batch-roll-change-a-revision-for-many-drawing...
It might not solve your immediate issues, but then again, it may change the way you currently operate?
Reg
2026.3
skatzY7HV8
Thanks Reg, this appears to solve the batch process issue.
It looks like you have done precisely what I am looking to do (you alluded to it here) - pdf and tacking the rev number at the end of the filename.
WIth the pdf plotter that we use (Bluebeam pdf), when I print to it a non-Inventor window pops up to allow the user to specify a file name. Can a rule control this external window?
Stephen
