Batch Plot IDWs to single PDF
Jesse_Glaze
Jesse_Glaze
I am looking for a solution that will plot all drawings associated with an assembly to a single PDF file. Basically, the resulting PDF file should directly mimic the all-level structured BOM of the assembly.
I have been browsing addons and see several (such as drawing porter) that pulls all drawings associated with an assembly, but none will plot everything to a single PDF.
I want to avoid printing individual PDFs and combining manually because that will be a huge task for a large project assembly (100+ drawings to merge). I have no stomach for repeating that task through multiple design revisions 🙄
Any ideas? If no current solutions exist, how hard would it be to build a custom script that uses the structured model BOM as a guide to create the PDF?
johnsonshiue
Hi Jesse,
Here is an old discussion thread about the same topic. Please take a look.
https://forums.autodesk.com/t5/inventor-forum/is-there-a-way-to-batch-plot-to-pdf/td-p/12160187
Another workflow is to leverage AutoCAD. Save the Inventor idw file to an Inventor dwg (or export to an AutoCAD dwg). Then open it in AutoCAD and use PUBLISH command to batch plotting all sheets to a pdf file.
Many thanks!
Software Test Engineer
Jesse_Glaze
Those suggestions do not satisfy my request.
Assembly Model/BOM Structure:
  • Main Assy
    • Weldment 1
      • Part 1
      • Part 2
    • Weldment 2
      • Part 1
      • Part 3
I have one inventor drawing created for each of the items listed above (6x .idw files in total). Now I want to create a single PDF file that follows the same structure as the top level assembly:
Page 1: Main Assy
Page 2: Weldment 1
Page 3: Part 1
Page 4: Part 2
Page 5: Weldment 2
Page 6: Part 1
Page 7: Part 3
If there is an existing tool, that would be awesome. If not, I am thinking about using the Main Assy BOM (or an export of that BOM to .csv) as the file list. The problem is that I don't know how to plot multiple drawing files into one PDF using ilogic..
johnsonshiue
Hi! I think some sort of customization is required. @Curtis_Waguespack shared his iLogic rule on this prior discussion.
Many thanks!
Curtis_Waguespack
@Jesse_Glaze
The batch tool that Johnson pointed too would be a bit manual for your needs, and would not give you a single PDF.
Attached is a zip file with an iLogic rule that you can run on your top level assembly and it will PDF out a drawing of each model ( assuming the drawings exits), and then uses the itextsharp.dll to combine them into one file.
https://forums.autodesk.com/autodesk/attachments/autodesk/78/950214/1/PDF%20all%20combine.zip
To use this you need to place the itextsharp.dll in the folder as specified, and then change the PDF output file and folder to your needs.
Example:
outputs where my top level assembly was 1234-0-ST.iam, which had a drawing, and 2 components in the assembly had drawings. So 1234-0-ST_Combined.pdf is the final output with all 3 PDFs combined into 1.
Hope that helps,
Curtis
AddReference "C:\Users\Public\global references\itextsharp.dll"
AddReference "System.IO"
Class ThisRule
	Shared _Folder_Path As String = String.Empty
	Shared _PDF_Name As String = Nothing
	Shared _GetPDF As String = String.Empty
	Sub Main()
		'set the name of the new pdf you want to create without the extension
		_PDF_Name = IO.Path.GetFileNameWithoutExtension(thisdoc.document.fullfilename) & "_Combined"
		'set the path of the folder contaiing all of the pdfs
		_Folder_Path = "C:\Temp\My PDFs"
		If Not System.IO.Directory.Exists(_Folder_Path) Then
			System.IO.Directory.CreateDirectory(_Folder_Path)
		'call the sub to created PDFs for all drawings from the current assembly
		Call PDF_ALL_Docs
		'get the PDF result
		Dim OpenPDF As String = CreatePDF(_Folder_Path)
	End Sub
	Sub PDF_ALL_Docs
		'define the active document as an assembly file
		Dim oAsmDoc As AssemblyDocument
		oAsmDoc = ThisApplication.ActiveDocument
		oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
		'check that the active document is an assembly file
		If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
			MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
			Exit Sub
		'get user input
		RUsure = MessageBox.Show( _
		"This will create a PDF file for all of the asembly components that have drawings files." _
		& vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
		& vbLf & " " _
		& vbLf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _
		& vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ", MessageBoxButtons.YesNo)
		If RUsure = vbNo Then
			Return
		Else
		'- - - - - - - - - - - - -PDF setup - - - - - - - - - - - -
		oPath = ThisDoc.Path
		PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
		oContext = ThisApplication.TransientObjects.CreateTranslationContext
		oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
		'oOptions.Value("All_Color_AS_Black") = 0
		oOptions.Value("Remove_Line_Weights") = 1
		oOptions.Value("Vector_Resolution") = 400
		oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
		'oOptions.Value("Custom_Begin_Sheet") = 2
		'oOptions.Value("Custom_End_Sheet") = 4
		'get PDF target folder path
		oFolder = oPath & "\" & oAsmName & " PDF Files"
		'Check for the PDF folder and create it if it does not exist
		If Not System.IO.Directory.Exists(oFolder) Then
			System.IO.Directory.CreateDirectory(oFolder)
		'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -
		'look at the files referenced by the assembly
		Dim oRefDocs As DocumentsEnumerator
		oRefDocs = oAsmDoc.AllReferencedDocuments
		Dim oRefDoc As Document
		'work the the drawing files for the referenced models
		'this expects that the model has a drawing of the same path and name
		For Each oRefDoc In oRefDocs
			drawingPathName = Nothing
			'check to see that the model has a drawing of the same path and name
			drawingPathName = Left(oRefDoc.FullFileName, Len(oRefDoc.FullFileName) -3) & "idw"
			If (System.IO.File.Exists(drawingPathName)) = False Then
				drawingPathName = Left(oRefDoc.FullFileName, Len(oRefDoc.FullFileName) -3) & "dwg"
					Continue For
			Logger.info(oRefDoc.FullFileName)
			Dim oDrawDoc As DrawingDocument
			oDrawDoc = ThisApplication.Documents.Open(drawingPathName, False)
			oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3)
			'Set the PDF target file name
			oDataMedium.FileName = _Folder_Path & "\" & oFileName & "pdf"
			'Write out the PDF
			PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
			'close the file
			oDrawDoc.Close
		Next
		'- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
		drawingPathName = ThisDoc.ChangeExtension(".idw")
			drawingPathName = ThisDoc.ChangeExtension(".dwg")
		If Not drawingPathName = Nothing
			oAsmDrawingDoc = ThisApplication.Documents.Open(drawingPathName, False)
			PDFName = IO.Path.GetFileNameWithoutExtension(thisdoc.document.fullfilename)
			oDataMedium.FileName = _Folder_Path & "\" & PDFName & ".pdf"
			'Write out the PDF
			PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
			'Close the top level drawing
			oAsmDrawingDoc.Close
		Else
			Logger.info("Could not find top level drawing")
			Logger.info(drawingPathName)
	End Sub
	Private Function CreatePDF(_Folder_Path As String)
		Dim bOutputfileAlreadyExists As Boolean = False
		Dim sOutFilePath As String = IO.Path.Combine(_Folder_Path, _PDF_Name & ".pdf")
		'sdet up return for a successful pdf. ret changes to FALSE if any errors occur for qualifying purposes
		Dim ret As String = sOutFilePath
		If IO.File.Exists(sOutFilePath) Then
			Try
				IO.File.Delete(sOutFilePath)
			Catch ex As Exception
				bOutputfileAlreadyExists = True
			End Try
		Dim iPageCount As Integer = GetPageCount(_Folder_Path)
		If iPageCount > 0 And bOutputfileAlreadyExists = False Then
			Dim oFiles As String() = IO.Directory.GetFiles(_Folder_Path)
			Dim oPdfDoc As New iTextSharp.text.Document()
			Dim oPdfWriter As iTextSharp.text.pdf.PdfWriter = _
			iTextSharp.text.pdf.PdfWriter.GetInstance(oPdfDoc, New IO.FileStream(sOutFilePath, IO.FileMode.Create))
			oPdfDoc.Open()
			System.Array.Sort(Of String)(oFiles)
			For i As Integer = 0 To oFiles.Length - 1
				Dim sFromFilePath As String = oFiles(i)
				Dim oFileInfo As New IO.FileInfo(sFromFilePath)
				Dim sFileType As String = "PDF"
				Dim sExt As String = PadExt(oFileInfo.Extension)
				Try
					AddPdf(sFromFilePath, oPdfDoc, oPdfWriter)
					ret = "FALSE"
				End Try
			Next
			Try
				oPdfDoc.Close()
				oPdfWriter.Close()
				Try
				Catch ex2 As Exception
				End Try
			End Try
		Dim oFolders As String() = IO.Directory.GetDirectories(_Folder_Path)
		For i As Integer = 0 To oFolders.Length - 1
			Dim sChildFolder As String = oFolders(i)
			Dim iPos As Integer = sChildFolder.LastIndexOf("\")
			Dim sFolderName As String = sChildFolder.Substring(iPos + 1)
			CreatePDF(sChildFolder)
		Next
		Return ret
	End Function
	Private Sub AddPdf(ByVal sInFilePath As String, ByRef oPdfDoc As iTextSharp.text.Document, ByRef oPdfWriter As iTextSharp.text.pdf.PdfWriter)
		Dim oDirectContent As iTextSharp.text.pdf.PdfContentByte = oPdfWriter.DirectContent
		Dim oPdfReader As iTextSharp.text.pdf.PdfReader = New iTextSharp.text.pdf.PdfReader(sInFilePath)
		Dim iNumberOfPages As Integer = oPdfReader.NumberOfPages
		Dim iPage As Integer = 0
		Do While (iPage < iNumberOfPages)
			iPage += 1
			oPdfDoc.SetPageSize(oPdfReader.GetPageSizeWithRotation(iPage))
			oPdfDoc.NewPage()
			Dim oPdfImportedPage As iTextSharp.text.pdf.PdfImportedPage = oPdfWriter.GetImportedPage(oPdfReader, iPage)
			Dim iRotation As Integer = oPdfReader.GetPageRotation(iPage)
			If (iRotation = 90) Or (iRotation = 270) Then
				oDirectContent.AddTemplate(oPdfImportedPage, 0, -1.0F, 1.0F, 0, 0, oPdfReader.GetPageSizeWithRotation(iPage).Height)
			Else
				oDirectContent.AddTemplate(oPdfImportedPage, 1.0F, 0, 0, 1.0F, 0, 0)
		Loop
	End Sub
	Private Function PadExt(ByVal s As String) As String
		s = UCase(s)
		If s.Length > 3 Then
			s = s.Substring(1, 3)
		Return s
	End Function
	Private Function GetPageCount(ByVal _Folder_Path As String) As Integer
		Dim iRet As Integer = 0
			iRet += 1
		Next
		Return iRet
	End Function
End Class
rvieiraWPK9V
Hello Curtis,
You script works well thank you very much for your help !
However, I get an error when aggregating the .pdf is does not work. The file is created but corrupted/empty. Have you had this issue too ?
Thankyou !
Rui
steveh5
If you have Vault...here's an alternative method with no scripting. We use it all the time.....
Based on your pdf settings, can batch plot as one pdf or as a single.
https://forums.autodesk.com/t5/vault-forum/drawing-lists-or-packages-for-a-given-top-level-assy/m-p/...
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
