I'm new to Inventor and 3D modeling in general and I just have a quick ( and probably stupid) question about the shell function. If I have a 3d solid object, and I shell it outwards, is the volume between the original walls and the new outside walls hollow or filled?
Thanks, and sorry if this has been answered before, I couldn't find an answer from my searching.
Solved by JDMather. Go to Solution.
Filled.
You can check this by going to View>Section View
I would expect it to be a solid.
See this page from the online help:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-899C322D-651C-47D5-801D-D5E737BAC08D
Steve Walton
