Base view missing command tab
Hi all!
I'm working on Inventor 2016 and i have to do a drawing but the base view command tab doesn't appear when i click on it (as in the image attached). This also happens with the iProperties tab.
Thank you!
Sergio
This widget could not be displayed.
JDMather
Have you installed all Service Packs and Updates?
Have you been using two monitors (could it be off of the edge of the screen)?
i guess so, last week i worked normally with drawings and all the commands.
No, i only use my laptop.
Sergio
Cadmanto
Sergio,
Welcome to the forum.
Are you talking about this not showing up?
If so, is it possible if you are using a laptop it is hidden behind your main Inventor screen?  I sometimes will disconnect my laptop from the docking station which is connected to 2 monitors and use the single flip up screen attached to the laptop.  Clicking through and on programs, sometimes windows don't show up because they are either hidden behind other windows or off screen because they were previously on the second monitor.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Curtis_Waguespack
Hi sa.rivas219,
To add to what Cadmanto and JDMather said:
Maybe the dialog is coming up off screen, as described at this link:
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
See that link for how to get it back.
I hope this helps.
Curtis
Hi Curtis,
i already did what is shown in your blog but the dialog stil doesn't appear, it moves but doesn't show up. A video of the process is recorded from Screencast.
Curtis_Waguespack
Hi sa.rivas219,
Maybe the Inventor Reset Utility will fix it.
See link:
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
I hope this helps.
Curtis
