I'm using AIP 2013. In our company there's a need for barcoding drawings.
I've added the text block in TTF font of "free 3of9 extended" barcode, extended for non-numeric characters in part number.
To this point everything works fine: I can print drawing directly from AIP, print .pdf using Bullzip pdf printer and the code is readable.
BUT!
When I generate pdf or dwf using AIP export functions it generates barcode unreadable for scanner.
When I copied the code from generated pdf and pasted it into MSWord, unwanted characters occurred in barcode, SPACES were generated after each character in barcode text box. Also code generated is smaller than in .idw.
Is there some kind of help for this? Is this the generator bug?
Source .idw
generated and printed .pdf
AT
BUT!
Source .idw
AT
