@mcgyvr wrote:
No default option to show "or" and frankly I can't think of a situation where "or" would ever be allowed on an assembly drawing..
How do you maintain proper inventory levels and consistency if you allow assemblers to "pick" one part or another to use in an assembly?
The way we called it out in the drawing was a little different, but at my previous company we did something that may be a decent example of where it would make sense. We had a shim (used for adjusting bearing endplay) that was available in three thicknesses. Only one shim was used in a unit, but which thickness was selected varied by the assembly tolerance stackup.
Inventory was dealt with by giving each unit a fractional quantity of all three shims in our MRP system. For example, if SHIM-2 was more commonly used, the quantities might be:
SHIM-1: 0.25
SHIM-2: 0.50
SHIM-3: 0.25
Obviously incorrect on a per-unit basis, but it averaged out to be reasonably close over time.
