Message 1 of 15
Hi all, this is my first post so sorry if I miss anything. I've got an '.idw' spares drawing which contains an assembly view and several exploded views.
The problem is with the balloon command not recognising parts in several of the exploded 'ipn' views. The balloons recognise one shaft washer but not the other shaft washer in the same view (identical parts). The same occurs in the other view where some parts are recognised but identical parts in the same view are not (bearings and sprockets this time). I've tried deleting/redoing views and parts, updating the drawing, turn it off and on but to no avail.
I'm currently using Autodesk inventor 2016, windows 7 pro 64-bit operating system.
