My ball bearing assembly is not working, I don’t know why I followed the tutorial on YouTube but still can’t figure out why it is not working. The problem will appear when I try to Pattern the ball. I attached below my screen record. Hope someone can help me.
Solved by johnsonshiue. Go to Solution.
Solved by blandb. Go to Solution.
Have you installed the latest update? I know there has been a free drag issue out there?
Hi! If possible, please install 2023.0.1 update. But, updates are only for subscribers. If you are on trial, you may not be able to get updates.
Many thanks!
Many thanks!
