Avoid Spring Elongation
francesco.bacchini
francesco.bacchini
Is there a way to prevent spring elongation when the referenced distance exceeds a certain value?
I don't want the spring to become unnaturally long when the batteries are pulled out from their compartment.
admaiora
Hi Francesco,
attach the assembly.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
francesco.bacchini
@admaiora here's my assembly
admaiora
Ciao Francesco,
something like this?
Admaiora
francesco.bacchini
Yes @admaiora , how can I achieve this result?
admaiora
You will find the assy attached.
The key is just use this type of function (min/max):
min(yourparameter;60 mm)
Where the funcion choose the lower value between yourparameter and 60 mm (in this case)
Admaiora
francesco.bacchini
Grazie mille @admaiora
