Announcements
Auxiliary view
Auxiliary view
hi
i got an Auxiliary view but I would like to rotate the view,
How can i do this?
Mark.Lancaster
Please show an example of what you are tryng to accomplish. Your words can be interpret different ways. Also when posting you should always include the Inventor being used.
Mark Lancaster
EvanGu
Right click the drawing view, there is a Rotate command, try the options to get your desired result.
Evan Gu
Inventor/Fusion QA Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous if you could provide a screenshot of what you're trying to accomplish that would clear things up.
I think you are referring to when you bring a part/assembly into the drawing (.idw) environment and it places a front view by default.
Please select the Accept as Solution button if a post solves your issue or answers your question.
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous did you get your Auxiliary View straightened out?
If you are still having issues please supply a bit more information so we can give you more detail.
deleted
Thank you
why i didn't saw it before :angry:
