Auxiliary View Label Property defaults
gkawkes
gkawkes
Currently using Inventor 2017. When creating a Section or Detail View, the view text label appears automatically. When creating an Auxiliary View, it doesn't. Not only is it not turned on, but to see it at all, you have to Edit View Label and insert the text "VIEW <VIEW>-<VIEW>". Whereas <VIEW> is the View Label parameter. Just to clarify, I DO NOT mean the reference arrows in the view you made it from. Also weird is, there is no way to edit the default for any of these view labels. The first pic is the View Annotation box. Clicking the pencil gets you to the Label Text box, where the rabbit hole ends. No way to specify View Labels. If you wanted to see "Sect. A-A" instead of "SECTION A-A", you're out of luck.
Any thoughts
mcgyvr
See here..
morgan_hrynkiw
Hi, I made this change in my styles editor and turned on the label visibility, but I still cannot get the auxiliary view labels to place with the drawing view. I have to manually edit each view and turn visibility on. Is there a fix for this?
