Auxiliary view export to dxf/dwg
I've got an Inventor dwg with multiple sheets that I'm doing a "save copy as" to a dxf and only the base and projected view geometry show up in the resulting files, however it doesn't include my auxiliary view. It will include the geometry if I uncheck "model geometry only" but that obviously includes a ton of other stuff annotations/etc that I don't want and have to clean up if I don't have to. Is there a way to get it to include auxiliary views in the resulted exported dxf/dwg file? The other option is to just place another base view of what I'm looking for but I'd much rather have it be an auxiliary if possible so it's still linked to the base.
Thanks!
johnsonshiue
Hi! The behavior you described sounds file specific. I am able to export auxiliary view to dwg without a problem. Could you share an example here or send it to me directly ([email protected])?
Many thanks!
Software Test Engineer
salariua
Is the drawing in Defer Update more? or the views in raster?
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
It's not in defer update or in raster.
I just tried with a brand new clean drawing and am getting the same result with a simpler drawing so maybe I'm doing something wrong if this is supposed to work.
Here's a screenshot/example of what's not exporting in case I'm describing it wrong.
I've sent off the file to Johnson as well.
Thanks!
johnsonshiue
Hi Evan,
Indeed, with Model Geometry Only option on, auxiliary views are ignored. I am able to reproduce it and it never seems to work. This is a great catch! I will work with project team to understand this behavior better and see how we can fix it.
Many thanks!
Johnson
was there ever any solution to this?  I am trying to export from inventor but the aux views do not come over.
johnsonshiue
Hi! I was looking for old emails I may have sent to the project team regarding this issue. But, I could not find it. I don't believe it has been resolved. Let me ask the project team again.
Many thanks!
