Automatically dimension and constrain sketch
Message 1 of 18
Whenever I have a problem to make a sketch fully constrained I use this button to constrain a sketch fully. So far it has not failed. I wish to know whether it is advisable to use this button. Help topic has very limited information about what I need.
Replies (17)
Message 2 of 18
JDMather
Forget that you ever saw that button.
Drag points and figure out what is needed.
Then you will no longer have this issue as you will have learned how to properly dimension and constrain a sketch.
Message 3 of 18
mcgyvr
I believe its always best to manually dimension and constrain (any constraints that aren't automatically inferred already) everything yourself.
But I have used that button a few times..
I would never recommend a new user presses that button..
Message 4 of 18
swalton
I don't use the automatic constraint/dimension button.
Instead I use the following:
  1. Project geometry that I need from the model origin or previous features.  Keep this to a minimum.
  2. Draw the sketch geometry that I need.
  3. Confirm the automatic sketch constraints and add new ones as required.
  4. Add dimensions to control the geometry.
Each step requires thought about my design goals, manufacturing requirements, company standards, how I expect the sketch to change as my design evolves over time, and how to structure the web of geometry, constraints and dimensions so that someone else can understand my model at a glance.  You will get better at considering all these factors as you gain experience with the tools.  I use a similar set of factors as I place and constrain components into assemblies.
I don't use the automatic constraint/dimension tool because it has no knowledge about all the above factors.
Look for the "Show All Degrees of Freedom" command from the Right Mouse Button menu while in a sketch.  That will show you the remaining DOF in your sketches and give you some direction for additional dimensions and sketch constraints.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 5 of 18
Problem is sometimes sketch is dark blue colour that means sketch is near to fully constraint but down right corner side of the window shows still couple of dimensions are needed.
Message 6 of 18
tschaeferZNBXX
I have NEVER used that button and STRONGLY advise you not to.  Using this button will make your life more difficult and hard to trouble shot any issues you have if the sketch gets sick.
If you understand the part you are make or sketch you are making there should be no need to use this button. It could add dims or constraints that mean nothing to your design but satisfy the criteria for a sketch to be fully constrained/dimensioned.
If you are learning Inventor or CAD why are you not asking your instructor?  Seems like you always ask the forum but get defensive when people try to help you.
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Message 7 of 18
It was my instructor told me use this button.
No demand here, only request. Choice left to mentors.
Sometimes help sometimes opinion. This is merely an opinion.
Message 8 of 18
swalton
Use the Show All Degrees of Freedom tool or JD Mather's vertex drag suggestion to learn where you missed a dimension or constraint.  Once you know what geometry is under-constrained, add dimensions/constraints to tie it down.  Don't just slap a dimension on a line, think about how that dimension will be used later in the design process and the life of the product.
Steve Walton
Inventor 2025
Message 9 of 18
JDMather
@Anonymous wrote:
...It was my instructor told me use this button.
I don't know whether to Smiley Very Happy or Smiley Sad or get Smiley Mad....
But the fact is - I seem to recall having covered this topic many many times, including videos.  I could be wrong, but ....
Did you see me stop - dazed and confused at 4:45 in this thread?  I expected the line to be constrained.  How did I solve my confusion?
Message 10 of 18
tschaeferZNBXX
Just seems lazy on their part then.
I would suggest putting your own dimensions that actually mean something that you can then retrieve when creating the drawings. It will speed your drawing creation up greatly.
*AU Speaker 2018*
* AU Speaker 2017 *
Message 11 of 18
Yes you covered many times. Particularly when I have a problem in examination hall myself has to solve the problem. When the time is limited I have to look for alternative methods. Because exam is mark oriented not knowledge oriented.
Message 12 of 18
tschaeferZNBXX
Ok so you are using the forums to answer your questions while you are taking an exam?
*AU Speaker 2018*
* AU Speaker 2017 *
Message 13 of 18
JDMather
In my experience having taught hundreds of Inventor users - the single most important concept might be to drag endpoints when sketches don't become constrained as expected (and there should be a logical expectation).
...and we haven't even started on Design For Manufacturability issues yet.
When does your class end?  It won't matter how good you are with Inventor if you never learn DFM right long side of the design tool.  In my experience if this isn't learned at the same time - students get stuck on designing modeling perfect parts that cannot be manufactured.
Message 14 of 18
Curtis_Waguespack
Hi fiatnm ,
In the Automatic Dimension tool you can un-select the Dimensions check box and let it only put on only sketch constraints.
I do use it this way occasionally.
Like everyone else has said, I do not recommend using this tool as a matter of common practice. If you develop proper practices and good sketch and constraining skills the need to use this tool to apply constraints will only arise when trying to work with someone else's poorly sketched mess. Smiley Wink
In this picture it says 2 Dimensions required, but in reality it is 1 sketch constraint.
I hope this helps.
Curtis
Message 15 of 18
My college is thinking to discontinue teaching inventor and going to start Solid Works which is very much popular among employers.
Message 16 of 18
tschaeferZNBXX
Has nothing to do with what software it has to do with how to design something that can be produced in the real world. I can make many things in Inventor/Solidworks/ Pro -E but they are not able to be produced.
*AU Speaker 2018*
* AU Speaker 2017 *
Message 17 of 18
Thank you.
Message 18 of 18
JDMather
I also teach SolidWorks.  There is essentially zero difference between the two programs (until you get to advanced topics like Dynamic Simulation).
The DFM has nothing to do with software used.
But teaching of both the software and DFM issues assumes expert experience in both.  This is a professional field of study and deserves a professional level of preparation.  There is no magic software button.
