Automatically deselect construction line when selecting new command
olof_andersson
olof_andersson
When I am drawing a sketch and I want a construction line I select the constuction line then draw the line and I get a constuction line, so far so good. But when I select a new command, say to draw a circle, the construction line is still selected, I know that this is as intended but I do not want this, I want the construction line to be deselected when choosing a new command. Can some lines of code solve this?
CCarreiras
Hi!
I almost never activate the construction mode, just because the "issue" you pointed.
Instead of that, i swap between construction or profile geometry very quickly, so, i draw the sketch and then i select what i want as construction geometry on the fly.
Tip:
Also i set the projected geometry as construction (since most of times the projected geometry serve as a reference), but... If i need it as profile geometry, i do the opposite, i turn the construction geometry into profile geometry on the fly.
Check the video below:
(view in My Videos)
CCarreiras
