From the link I provided above:
Function _GetHoleCountAndDiameters(oPartDoc As PartDocument) As Double(,)
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oTO As TransientObjects = ThisApplication.TransientObjects
Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oSizes As New List(Of Double)()
Dim oLines As ObjectCollection = oTO.CreateObjectCollection
Dim oTestLine As Line
Dim oIsExisting As Boolean
For Each oFace As Face In oPartDef.SurfaceBodies.Item(1).Faces
If oFace.SurfaceType = 5891 Then
oTestLine = oTG.CreateLine(oFace.Geometry.BasePoint,oFace.Geometry.AxisVector.AsVector)
oIsExisting = False
For Each oLine As Line In oLines
If oLine.IsColinearTo(oTestLine) Then oIsExisting = True
Next
If Not oIsExisting Then
oLines.Add(oTestLine)
oSizes.Add(oFace.Geometry.Radius*2)
End If
End If
Next
Dim oUniqueSizeList As New List(Of Double)()
For Each oSize As Double In oSizes
If Not oUniqueSizeList.Contains(oSize) Then oUniqueSizeList.Add(oSize)
Next
oUniqueSizeList.Sort
Dim oHoles(oUniqueSizeList.Count-1,1) As Double
For i As Integer = 0 To oUniqueSizeList.Count-1
oHoles(i,0) = oUniqueSizeList.Item(i)
oHoles(i,1) = 0
Next
oHoles(oUniqueSizeList.IndexOf(oSize),1) = oHoles(oUniqueSizeList.IndexOf(oSize),1) + 1
Next
Return oHoles
End Function
I heard back from the author, who states:
"This rule is simply a function I added to this library as per the forum post linked in the og commit message. It needs Sub Main End Sub added at the top, but also needs to do something with the resultant count. If you look at the https://github.com/AlexFielder/iLogic/blob/master/Modelling/FEATURECOUNT.iLogicVb rule it shows a way of using the data."
I added the Sub Main End Sub as he indicates, but I still could not get it to run.
Thanks for any help.
