Automatic setting filename to partnumber
Message 1 of 13
At work we are using a system to name our part as p.e. ABGO_100 where the ABGO stands for the project. Now I want to find a way to link the filename to the partnumber (because I often use ctrl-c and ctrl-v and then rename in explorer to generate more parts. And it's also in de library parts that I use. Is there a way to do as shown in my example:
First part: save as ABGO_100.ipt partnumber automatic ABGO_100
In explorer ctrl-c ctrl-v: ABGO_100 copy.ipt
Rename: ABGO_101.ipt partnumber automatic ABGO_101
This would save me (and the company ofcourse) a lot of time.
Thx in advance,
Beli
Replies (12)
Message 2 of 13
Mark.Lancaster
@Anonymous
If I understand your requirements and assuming you don't use Vault.  Use the Inventor Design Assistant to rename your files as needed and/or to update part numbers.  Part numbers can also be updated through the Assembly BOM interface.  As a side note, the design assistant is not really user friendly so be patience with it..  Smiley Wink
Mark Lancaster
Message 3 of 13
ThomasB44
Hi @Anonymous,
I'm not a great fan of Design assistant, so in most of case, I copy and paste parts or assembly inside Inventor.
Then I use the "save and replace" command to quickly copy some design.
If your wish is to always have the part number equal to the filename you could run this kind rule in your top level assembly. This rule will set ALL sub files part number equal to the related file name. So at the end of your copy and paste task, you could run it only one time.
SyntaxEditor Code Snippet
'Check if it is an assembly
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
    MessageBox.Show("This is NOT an assembly document !", "iLogic",MessageBoxButtons.OK,MessageBoxIcon.Error)
    Return
End If
'Create variables
Dim FullFileName, FileName, PartNumber As String
Dim FNamePos As Long
'set a reference to the assembly component definintion
Dim asmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oDoc As Inventor.Document
Dim asmDef As AssemblyComponentDefinition
asmDef = asmDoc.ComponentDefinition
'Prevent message
If MsgBox("This will update the part number equal to file name in all sub files" _
& vbNewLine & "Do you wish to Continue ?", vbYesNo + vbQuestion, "iLogic") = vbNo Then Return
'Store referenced documents properties
For Each oDoc In asmDoc.AllReferencedDocuments
    FullFileName = oDoc.FullFileName 'With extension
    'Find last "\" position in full filename path string
    FNamePos = InStrRev(FullFileName, "\", - 1)
    'Extract FileName
    FileName = Mid(FullFileName, FNamePos + 1, Len(FullFileName) - FNamePos)
    PartNumber = Left(FileName,Len(FileName) - 4) 'Without extension
    iProperties.Value(FileName, "Project", "Part number") = PartNumber
Next
You could also have an external rule, set with an event trigger to each of your parts, but I think it will be less friendly to use.
Thomas
Mechanical Designer / Inventor Professional 2025
Inventor Professional EESignature
Message 4 of 13
not completely what I was looking for but tested this method and I'm going to use it. Thank you! 🙂
Message 5 of 13
'SAVE COPY AS' Would do both at once since UNFORTUNATELY, Part Number=File Name upon creation... which i still find insanely frustrating and pointless.
Message 6 of 13
NachoShaw
From a top level assembly, you could write a bit of code to (if i understand correctly):
select part from assembly
open invisible
get part number
change from ABCD_100 to ABCD_101
save as new part number (automatically updating the Part number field)
optionally add new part into assembly
if thats what you need, i can write up a bit of code for that
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 7 of 13
@ThomasB44  Thank you very much, that is what i am looking for.
Message 8 of 13
geralJD3XV
Is there a way to do the opposite? Change the file name to be equal to the part number?
Message 9 of 13
A.Acheson
The original code has allready found the filename so make it equal to the partnumber.
An easier method to get the filename is using the system.IO functions see source documentation here
Dim FileName as String = System.IO.GetFileNameWithoutExtension (oDoc.FullFileName)
iProperties.Value(FileName, "Project", "Part number") = FileName
Regards
Alan
Message 10 of 13
geralJD3XV
Thank you for the help. I tried what you said but it didn´t work.
Can you help me figure out what i am doing wrong here?
    Return
End If
'Create variables
'Prevent message
    'Extract FileName
    FileName = PartNumber
Next
Message 11 of 13
A.Acheson
@geralJD3XV @Sorry I had a brain freeze yesterday. Changing the filename to be the part number is a much bigger task depending if you have subassemblies and parts in your assembly. You will need to perform a save as/replace file references. I suggest posting this as a separate post as it is a separate topic than the original and it will be complicated. Here is a working post that is renaming the files by creating a brand new set of files using save as then for the reference documents performing a replace reference. Exactly how you would do this manually. The only tweak you will need is to change the filename to be the partnumber of the file before it is saved.
Regards
Alan
Message 12 of 13
RudolfVanDerSpuy
Hi there:
I have exactly the same problem.  I also tried to restructure the ilogic  code and arrived at the exact same point and it does not work. The fact that one can use Design Assistant to do the renaming , by copying the part number and naming the file name accordingly means that there are no obvious conflicts. It is however the typical pain in the neck job using DA and I am sure that ilogic can resolve the issue. @A.Acheson  suggested a new post. @geralJD3XV  Have you had any joy?
Message 13 of 13
RudolfVanDerSpuy
Good day. If you have not resolved your problem in this regard: I have a piece of iLogic code that can help with this.
