Automatic Extrusion from Standard Parts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Afternoon All,
I'm hoping that one of you will be able to help me with my current predicament.
A bit of background before I start.
I have been tasked by my company to streamline the Estimating, Design and Production process for Flight Cases that we produce in house.
I have successfully created the shell of the case by linking all the individual components to Length Width and Depth Parameters. Which allows me to change the overall size of the case relatively quickly.
My current sticking point is when it comes to the addition of fixings on the case (Latches, Hinges, Handles, Etc). They are all premade supplied parts which I have the individual Cad Models (Step) for. I am looking to automatically add in cuts into the extrusion/panel at the part level. Wherever one of these fixings is placed. So that further down the line I can using inventors nesting software to automatically generate DXF Machine files. I'm looking to have to do as little physical input for each part as possible as these cases can come with multiples of each fixing depending on the end user’s requirements.
These cuts also are not an exact match to the profile of the part itself. So, to the best of my knowledge copy object and then sculpt wouldn’t work.
Take one of the handles as an example. (This cut-out I have done manually.) The fixing holes are an exact match, but the main cut-out is simplified from the main profile of the handle.
If you need any more info just let me know.
Kind Regards
Will.
