Automatic Draft angle option?
m.nachmazov
m.nachmazov
Can Inventor do automatic draft angles for injection molding? Basically I would model a part without using 1-2 degree angles and at the end I would use automatic draft angle and Inventor would apply 1-2degree angles to walls in appropriate direction. Is there any funtion as this?
Thank you
Gabriel_Watson
Have you tested the Draft function under the 3D Model tab (IPT/part environment)?
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-38133835-2EDB-414E-ACB1-2487A96900F7
