Automated centerlines
NigelHay
Advisor Advisor
Message 1 of 9
NigelHay
When I'm dimensioning circular components & the section view is a bit crowded, I often pull out a larger scale detail view from the section & dimension that. In order to dimension diameters, I use the automated centerline command to generate the centerline then use linear diameter dimensions. With the last few drawings I have done the automated centerline command has not produced any result unless I expand the detail view so that it includes the centre of the circular part. In the past this was not necessary, Inventor was happy to add a centreline outside of the detail view boundary. Is this a deliberate change or is this behaviour wrong?
Inv 2019 pro
Replies (8)
Message 2 of 9
johnsonshiue
Hi Nigel,
Are you talking about the centerline in the Base View? Could you share an example here? I think it could be as designed but I want to double-check and make sure it is true.
Many thanks!
Software Test Engineer
Message 3 of 9
NigelHay
Not the base view, the detail view. In the drawing attached, I had to expand the detail call-out until it included the centreline before the automated centreline command would give a result. After dimensioning I was able to reduce the call-out again. This has happened with the drawings over the past month or 2, previously, the command would produce a centreline outside of the call-out area.
Message 4 of 9
johnsonshiue
Hi! Do you mind elaborating the steps to see the issue? I have downloaded the files but I don't know how to reproduce the problem.
Many thanks!
Message 5 of 9
NigelHay
This is very strange, I set out to reproduce the problem using the same component. I create a section view then, a detail view of just the edge detail. I use automated centrelines within that small detail view & it now seems to be working properly, creating a centreline outside of the detail view boundary. I've tried this today with a couple of different components & it seems to be working just as it should. Over the past couple of months it was not working.
Either this was a temporary glitch or your influence is so powerful, the mere sight of your name has shocked Inventor back on the straight & narrow path.
Message 6 of 9
johnsonshiue
Hi Nigel,
Many thanks for letting me know! I suspect there is still a bug somewhere. Please let me know if you find the way to reproduce. I will play around with your files too.
Thanks again!
Message 7 of 9
perspicax
I am currently experiencing this issue -- Taking a Detail view from a Section and the Detail will not generate the Automated Centerlines from the turned features.
This used to work and I think this is a bug.
I found a separate Autodesk page that says a workaround is using a Smooth Cutout Shape for the Detail. I tried and it still didn't work.
I have attached the part and drawing -- Detail B will not generate Automated Centerlines.
Message 8 of 9
johnsonshiue
Hi! Many thanks for sharing the files! It does look like a bug to me. I cannot explain this behavior. Let me work with the project team to understand it better.
Thanks again!
Message 9 of 9
johnsonshiue
Hi! This is indeed a known defect. It was logged as INVGEN-17961, which has not been fixed yet.
Many thanks!
