Automate the drawing annotations of coped pipes
boothdrafting
boothdrafting
New to BOMs in inventor, bear with me...
I am often making drawings of railing assemblies, sometimes with coped pipes, as pictured above. Currently, I have to create the part views, draw a sketch, and dimension all of my pipes that are coped and angle cut. I would like to get to the point where I don't even need to create drawings for these pipes, and instead I can have the necessary dimensions (shown above) in the BOM.
Is there a way to create these dimensions as custom parameters?
Or could I use iLogic to automatically create a drawing for each one of my frame members?
I'm considering not using any notches in my model... this would likely solve my problem, but I would then have to manually specify which pipe ends need to be coped.
Also... the CUTDETAIL parameter is giving me the complementary of the cut angle. I could make a custom parameter of "CUT = 90-CUTDETAIL#" to get my actual cut angle, but the CUTDETAIL number is not consistent to the type of detail. Is there a workaround for this problem?
TYIA
Inventor 2021
mcgyvr
Can you post one of your pipe files?
Are you using frame generator for these pipes?
and do you really go out to 4 digits? Thats some uber precise pipe..
johnsonshiue
Hi! Indeed, there are quite a few questions asked in this posting. It is like how to automate creating drawing views and annotations for custom frames. There isn't an out-of-box solution. Regardless, it is doable with iLogic. I have seen quite a few examples, but I cannot share proprietary data.
Please share an example you are working on. We have quite a few iLogic experts on the forum to provide guidance.
Many thanks!
Software Test Engineer
boothdrafting
@mcgyvr
Here's the pipe file. It's a custom part that I made for use with the frame generator.
Haha, no our sizes are not that precise. I draw to 4 decimals because it tells me if the dimension is true, or rounded off (which is sometimes a red flag).
