Automate drawing views scale within border limit as model changes.
Hello, Forum
 I'm new to inventor and this forum. I would like to know if I can automatically scale drawing views within the limits of a drawing sheet (8-1/2" x 11") as the model changes in size?  For example, as i change my model size with ilogic. I would like for the drawing views to update and scale approriately and stay within the border limits automatically. That way i don't have to go into the drawing viewport and change the scale factor manually.  If someone can direct me to a link, to a video or tutorial or any other kind of help would be greatly appreciated.
Thank You.
salariua
I am having a deja-vu.
Can't be bothered so I just copied over my previous reply:
You might want to post this on the Inventor Customization Forum.
This is what you need:
http://forums.autodesk.com/t5/inventor-customization/ilogic-coding-to-create-automated-drawing/m-p/3...
And the code from that post on how to move and scale views.
Go give them kudos if it solves your problem.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Thanks Adrian S.,
Your guidance help me find another posting in the recommendation section. That is somewhat similar to what i was looking for. I appreciate your time.
Thanks again!
Cadoor
salariua
Glad you found what you needed, ... and welcome to the forum.
Adrian S.
blog.ads-sol.com
