Autodesk Viewer/Autodesk Drive
bradford253
bradford253
I have been uploading large models to Autodesk Viewer in order to share them with my customer. However, He is asking if I can leave them out there longer than 30 days. Then I discovered Autodesk Drive but am having trouble uploading files to Drive. When I try to create step files to upload my Inventor crashes. Is there a way to copy files from Viewer to Drive?
CCarreiras
Hi!
It's Not possible to copy from viewer to drive.
Tip: as a workaround, after the 30 days, you can always upload the model to more 30 days... and so on.
CCarreiras
pcrawley
Try this:  Create a DWF from Inventor, then upload the DWF using Autodesk Drive: https://drive.autodesk.com/home (There's an upload function - or you can just drag-and-drop into the web page.)
Once your DWF is uploaded, you can enable the link and share it:
The advantage of the DWF is that you can chose which iProperties are included when you publish the DWF (and they become visible in the viewer) - plus the DWF is a tiny file compared to either Step or the full .iam and all its component parts.
Peter
James_Willo
Hi, you can extend the 30 days as much as you like, but you have to do it manually and keep going in to add another 30 days.
James W
Inventor UX Designer
James_Willo
Click your profile in the top right and then 'design views.'
Next to the file you want, click extend
James W
bradford253
Thank you for that excellent advice. It worked fine.
Brad
