Autodesk Inventor Turning Simulation
Message 1 of 10
could we do turning simulation in Autodesk Inventor 2016 like a metal chip removal, and determine the magnitude of residual stress?
Replies (9)
Message 2 of 10
mdavis22569
Welcome to the forum ....
I'm not familiar with HSM .... but check it out ..
I'm sure a few others will jump in and help that are familiar with it
http://cam.autodesk.com/get-inventor-hsm/
Mike Davis
Message 3 of 10
Marco.Takx
Michael is right. Hier you can download the 30 days trail version of Inventor HSM or Inventor HSM Pro.
These are the CAM tools from Autodesk within Inventor that includes Turning.
At the moment there is no simulation for residual stress.
But you can simulate the toolpaths for colision detection.
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 4 of 10
not in autodesk inventor HSM, could autodesk inventor pro can solve my problem?
Message 5 of 10
blair
Not in Inventor Professional, I've never seen it done in Simulation Mechanical either. I'm sure that the tool manufactures that produce the insert bits and holders would have that data available as so much of it is dependant on the bit geometry and feed rates.
Delta Tau Chi ΔΤΧ
Message 6 of 10
so i can't do turning simulation in inventor pro like metal chip remover? have any idea for this solution
Message 7 of 10
blair
You can to turning with HSM within Inventor. The problem is it will only feed at rates specified by the tooling manufactures. There is no FEA to determine forces of the toolbit/workpiece interface.
Delta Tau Chi ΔΤΧ
Message 8 of 10
Thank you Mr. Blair
Message 9 of 10
LT.Rusty
Honestly, I don't know of ANY software that can do what you're asking.  There are just too many variables involved.  You'd almost certainly wind up having to get some serious custom programming stuff done.
Rusty
Message 10 of 10
swalton
You might try contacting the United States Cutting Tool Institute (or local equivalent) to see what their members use for this purpose.  See http://www.uscti.com/
Your local university with active research in manufacturing technology might have a professor or grad student that can provide you some leads for any commercially available software.
Google has a few listings under "metal cutting simulation software" and "finite element analysis of metal cutting".
Steve Walton
Inventor 2025
Vault Professional 2025
