Autodesk Inventor - sketch module
ferreirahomeoffice
ferreirahomeoffice
As a suggestion, Autodesk could modify the Inventor sketch module to look like Fusion360, because it seems to me that the dimensions and lines in it are much more organized.
WHolzwarth
I agree, that Inventor sketch dimensioning is not perfect. I could think of coordinate sets additionally.
But let's look at F360:
- I don't like trailing zeros. But this can be set in Preferences -> Unit and Value Display -> Hide trailing zeros-> Minimum precision ... to 4
- I don't like the orientation of vertical dimension texts. This should be opposite, but I didn't find the setting.
Glad to see, that it seems to be possible. Look here:
https://knowledge.autodesk.com/de/search-result/caas/CloudHelp/cloudhelp/DEU/Fusion-Sketch/files/GUI...
Who knows about it?
Walter Holzwarth
TheCADWhisperer
The sketcher in Fusion is terrible?
johnsonshiue
Hi! There is absolutely room for improvement here. I will work with the project team and see what we can do.
Many thanks!
Software Test Engineer
