Inventor Forum
Autodesk Inventor or Autodesk Revit for Residential Construction
1 REPLY 1
335 Views, 1 Reply
I would like some guidance on choosing a software package to make my life easier down the road.
I am a Licensed Mechanical Engineer in the Reciprocating Air Compressor sector and use Inventor on a daily basis to do my designs in.  I would rate myself as a 8 of 10 on experience with Inventor.  I have a couple of side projects coming up for a local resident construction company and I'm looking for a cad package that will make my life easier.  I've known of Revit  in the commercial construction industry.  I am debating using Inventor or Revit for doing residential construction drawings and models.  I would like to be able to do 2x4 wall easily through some sort of frame generator and make the design process go as quick as possible.  Does Revit have built in tools to make this easy?  I'm looking for a quick and easy solution.
Give me your input and let me know what you think?  Is the pay off of learning a new software (shouldn't be to hard) worth the rewards of Revit for residential use?  Is their another CAD package I should be looking at?
1 REPLY 1
adsk_loren
Have you looked at Factory Design Suite?
http://usa.autodesk.com/autodesk-factory-design-suite/
It includes AutoCAD Architecture, so you can build walls, etc. The Sync functionality might be more interesting, though. You can bring a DWG floor layout into Inventor, add your equipment, and then update the DWG.
Loren
Loren
