Dear Autodesk Support Team,
I am writing to report an issue I am experiencing with Autodesk Inventor. Whenever I use the nesting feature, the software crashes consistently. This problem is severely impacting my workflow and project timelines.
The OneDrive model I shared with you contains an assembly file for the autoclave assembly. When I try to nest the autoclave assembly, the nesting process crashes.
Hi, thank you for your answer. I tried to nest the main assembly and after about 20 min it finished successfully. It contains a lot of parts (around ~1500) and requires some time for Inventor to do the process. I think the crash might be caused by the hardware - please share some information about your PC (like graphic card, RAM etc) and I will check if it might be related.
Regards!
MY WORK STATION: HP Z2 TOWER G9 (WORKSTATION DESKTOP PC)
Processor : 13th Gen Intel(R) Core(TM) i9-13900K 3.00 GHz
Installed RAM : 64.0 GB (63.7 GB usable)
Edition Windows 11 Pro
Version 23H2
Installed on 06-03-2024
OS build 22631.3672
Experience Windows Feature Experience Pack 1000.22700.1009.0
DISPLAY ADAPTERS (GRAPHICS CARDS)
1. AMD RADEON PRO W6600
2. INTEL(R) UHD GRAPHICS 770
Are you able to record a video on how to cause a crash?
You can share it with me in a private message to avoid sharing sensitive data
"I'm facing crashes in my program, and it seems random. It's difficult to identify the trigger point. Is there anything I can do to debug these crashes more effectively?"
@umesh.javir_84, I see you mentioned when you disconnect your workstation from the network, it will work. But it will crash again after you connect back. Are there any source data are coming from remote server? If so, not sure if you can have a try to download the remote server data to your local and use them instead to see if the crash still happen?
all of our work, including parts, assembly, and drawings, is done on the same workstation. We only use the network for internet access and to log in to Autodesk Inventor.
@umesh.javir_84 , got it. So the issue should not relate to add remote sources.
From the symptom, it looks like caused by adding some specific source parts cause the crash. To debug the issue, if we can reproduce the crash stably, we may can try to identify which parts might cause the issue by trying to not add all the source files, but just add parts of them to narrow down the issue parts.
