Autodesk Inventor 2021 hangs when Open or Place from Vault
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I wasn't sure which forum to place this issue.
I installed Inventor 2021 and Vault Workgroup 2021 a week ago. Migrated my data from Vault 2019 and was using it for most of the last week without incident. Been able to create new vault items as well as access older elements, update and re check in.
Today, I tried to add an item from Vault into an existing Assembly, and Inventor's UI hung. I could still rotate and zoom the model on-screen, but none of the menu items work. Waited a dozen minutes and tried alt-tab to make sure it didn't simply pop up an off-screen dialog (None visible). No effect.
Vault Workgroup Server is on a separate PC on the same network. It's accessible and I'm logged into Vault in Inventor.
If I force-close Inventor and reopen, I can click the Vault button in Inventor, and it launches Vault. If I try to open or place anything from Vault while in Inventor, or inversely, if I select an item from Vault itself and try to open, Inventor just hangs. I don't seem to have any issues in Inventor until I try to do something that accesses files from Vault.
I tried rebooting. I tried shut-down and restarted. I tried Inventor Reset. None seem to have any effect.
I have Build 183, Release 2021.0.1 installed 5/5/2020
