Inventor Forum
Autodesk Inventor 2015 What's New
66 REPLIES 66
Message 1 of 67
24911 Views, 66 Replies
I know that the last few releases of the new version of Inventor have been towards the end of March timeframe - does anybody remember how much before that they release the What's New documentation? Also, is there any info on when the beta tester NDA is lifted - they're allowed to talk about it?
Just curious and excited to see what they've got in store for 2015. It'd be nice to see what our investment is bringing us!
66 REPLIES 66
Message 21 of 67
blair
in reply to: Curtis_Waguespack
This is one where "both" are correct or incorrect. The top edge of the hole through a curved face is a 3D poly line, yet the interior of the hole is a circle or if you project the 3d poly line to a flat surface the result is a circle.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 22 of 67
acad-caveman
in reply to: blair
Curtis
 Hmm .... I can't find it either, though I am quite certain to have listed it way back when I first switched to inventor with  V. 2011.
It is possible to have listed it in one of the other "wishlist" forms. If so, I stand corrected.
Blair
  Yes, the top edge is a polyline, but not when they are projected onto a flat plane which is normal to the axis.
As far as the projection ( view) is concerned, that is in fact a circle, just as it is a circle when you project it within the
sketch environment onto the very same tangent plane.
Which btw is another interesting thing.
If you take the attached IPT, create a tangent plane normal to the hole's axis, then project the hole's geometry, you will end up with a true circle.
Now, if you look at the same view in Inventor's drawing environment, the very same exact projection becomes 2 separate entities.
They are splines in the drawing environment, but Inventor does recognize them as circles with a radius and can be dimensioned as such.
However!
If you create a sketch on the same view and offset one of the arcs, they become pure splines without the ability to dimension them as an arc!
Anyhow, I have tested the 2D output from two different 3D modelers, neither behaves this way.
Message 23 of 67
blair
in reply to: acad-caveman
Here's a quick view of how Inventor places and works with items in a drawing. The items are not really on the drawing sheet, you really need to watch closely.https://chronicle.autodesk.com/Main/Details/afeae328-eb5a-4e1b-ac22-b8049d8e4976
Delta Tau Chi ΔΤΧ
Message 24 of 67
jdits7
in reply to: blair
Here are some of the detail regarding Inventor 2015, http://inventortopix.blogspot.com/2014/03/inventor-2015-whats-new.html
jdits7
Autodesk Inventor Certified Professional
Blog - http://www.inventortopix.com
Twitter - @InventorTopixJD
Message 25 of 67
cieslak.maciek
in reply to: jdits7
Message 26 of 67
in reply to: jdits7
Very nice list! I went through it on the computer I have the Inventor 2015 software on and checked out quite a few different things. Looks to be a pretty solid release, and it's easy to overlook the "under-the-hood" changes they work on to make geometry creation more robust.
Freeform looks also like an interesting development! I was just fooling around with it and I created a pretty cool looking motorcycle gas tank, at least the basic swoopy shape. A step in the right direction for sure!
Message 27 of 67
SBix26
in reply to: cieslak.maciek
@cieslak.maciek- can you post the pdf here?  I don't have access to dropbox.
Sam B
Message 28 of 67
jletcher
in reply to: SBix26
Here you go
Message 29 of 67
jdits7
in reply to: blair
I also have it posted on my blog under the Inventor What's New page, http://inventortopix.blogspot.com/p/whats-new-docs.html
Thanks James.
jdits7
Message 30 of 67
scottmoyse
in reply to: jdits7
Gavin Bath has created a post here, he's sharing opinion & an interesting way to present the new features to everyone. Where possible, he has also linked back to Ideastation posts. If you see any other Ideastation posts which can be linked back to it, please share them in the comments, I have no doubt he will jump in and add them where needed.
All in all, it's a very good release of Inventor. It's been just as stable as 2014 for me for the last couple of months. Sure people will be unhappy their area of Inventor hasn't been improved, but the sketch changes are HUGE & should help every single Inventor user on the planet. I can't wait to get stuck into helping people with it.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 31 of 67
karthur1
in reply to: scottmoyse
I think they did a great job with 2015.
A few things that I really like are:
1. They finally labeled the workplanes.  The origin planes and user defined workplanes will show their name when you hoover over them (if they are visible).
2.  The vertical and horizontal constraints, show you what is vert or horiz before you place the constraint.
3.  They cleaned up how constraints are shown in sketch.
A preview is here.
Its little things like this that makes Inventor better to use. I am not a big fan of the "Home Screen", but at least we can turn it off so its not displayed.  Wonder how much RAM it sucks even with it not displayed?
Kirk
Message 32 of 67
in reply to: karthur1
Inventor 2015 is still not available to me on the subscribtion website.
Does anyone know when it will be available for download?
Brgds,
Chris
Message 33 of 67
scottmoyse
Only AutoCAD, It's verticals & Vault are so far. I think a few more will pop up over the weekend. Suites normally come last.
Scott Moyse
Message 34 of 67
blair
I thought the Design Suites usually showed up the first week of April.
Delta Tau Chi ΔΤΧ
Message 35 of 67
mslosar
in reply to: blair
AutoCAD typically hits the middle of March. From there, it takes up til towards the end of April before the rest of the products hit - things like Inventor, Revit, 3DS Max, Alias stuff, etc. Inventor and Max are typically the beginning of April from what I recall, but it's definitely a prolonged rollout of all the different products. Considering Suites have most all those prodcuts, they're usually last in the line.
Message 36 of 67
blair
in reply to: mslosar
Just got the e-mail from ADSK on what is now in the Suites, dang no Showcase. Somehow 3dMax looks far more difficult to learn than Simulation Mechanical and Inventor combined. Dear Autodesk Product Design Suite Subscription Customer, We are happy to inform you that effective April 16, 2014, we have updated our Product Design Suite 2015 offerings (English version). These updates were made based on customer feedback on providing the most valuable tools to address your needs. • Product Design Suite Premium 2015 will include Autodesk® Inventor, Autodesk® AutoCAD®, Autodesk® AutoCAD® Mechanical, Autodesk® AutoCAD® Raster Design, Vault Basic, ReCap, 3DS Max Design and Navisworks Simulate. • Product Design Suite Ultimate 2015 will include all the products in Product Design Premium 2015 plus Autodesk® Inventor Professional, Autodesk® AutoCAD® Electrical and Navisworks Manage. • Autodesk® Product Design Suite Standard will no longer be available. What does this mean for you and what happens next? If you purchased Maintenance Subscription you will benefit from the new Product Design Suite 2015 offerings at no additional charge or change to your current maintenance subscription fees: • As a customer with Product Design Suite Standard on a current Maintenance Subscription (formerly Subscription) contract-as of April 16, 2014- you will automatically receive Product Design Suite Premium 2015. • As a customer with Product Design Suite Premium on a current Maintenance Subscription (formerly Subscription) contract-as of April 16, 2014 - you will automatically receive Product Design Suite Ultimate 2015 with your current level of support. • As a customer with Product Design Suite Ultimate on a current Maintenance Subscription (formerly Subscription) contract-as of April 16, 2014 - you will automatically receive the new Product Design Suite Ultimate 2015 offering. You will receive a notice when the new suite becomes available for download on Subscription Center or Autodesk Account. Learn more about Autodesk® Product Design Suites 2015 Costs There are no additional Maintenance Subscription costs for the remainder of your current contract. There is no suggested retail price increase for maintenance subscription renewal for calendar year 2014. Please note that Autodesk resellers are free to set their own prices for Autodesk Maintenance subscriptions and renewals. Please feel free to check out the following options in case you have further questions: Learn more about this change by viewing the customer video or contact your Autodesk Authorized Reseller, or Autodesk sales representative.
Delta Tau Chi ΔΤΧ
Message 37 of 67
cieslak.maciek
They discontinued Showcase, so it can't be in the Suites. I thought that they would come up with a simplified, more user friendly version of VRED if there is no Showcase...well as we can see they didn't. Shame.
Message 38 of 67
scottmoyse
No they haven't discontinued it! Its just not in PrDS, its still in factory design suite though
Regards
Scott Moyse
MFG Technical Specialist
CADPRO Systems Ltd
0210557775
>From my Windows Phone
Scott Moyse
Message 39 of 67
On the Autodesk page for Factory Design Suite 2015 there is an Astrix next to Showcase.
It may be in the Suite but I wonder if the Astrix will be bad news............(Like 2014 version) but I cannot find what the Astrix means on the web page.
Inventor 2023
Message 40 of 67
cieslak.maciek
 But is it new version of software, or just old Showcase with new badge on it? I heard that becasue of VRED they will not develop showcase any further.
