I was wondering if anyone knows if there is a way to take lines from a 3D model in autocad 2014 and use that line to make a part in Inventor 2014. If anyone could help it would be greatly appriciated. Please list all steps in depth if possibe. Thankyou!
______Trying to make the exact windshield supports on this model into a part on inventor______
Solved by JDMather. Go to Solution.
File Open and click the dwg,
but
BEFORE
opening click on Options and set to Import,
now open and follow the Wizard.
but
BEFORE
It took me to the application menue and i selected the file but nothing happened when i clicked open.
Attach your dwg file here.
It won't let me send it the file is too big dude.
@Anonymous wrote:
the file is too big
Check out the instructions in this thread for large files (not including the EOP info).
Upload to A360
@Anonymous wrote:
the file is too big
Upload to A360
Thanx dude i got it. I did it wrong the first time...ur a genius!!!! thanx a million...
how do i get the specific part i want and when i it how do i convert it into a part????
You didn't follow the Wizard correctly - you are in a drawing, not a part file.
Make sure to use these settings.
Depending on what you have in your source - you might want to Project wires to 2D sketch rather than 3D sketch.
But make sure the geometry is going in to a New Part rather than Drawing.
thank you sooo much...i really appriciate you helping me even though im not the best at using this software. Thanyou thankyou thankyou!!!!
