auto scale ipart based on another ipart in an assembly
Hello experts,
this question has two parts.
I'm trying to autoscale a part when placing it in an assembly. I can autoscale the part by linking it's parameters to those in the assembly but in this case I would like to scale based on another component.
My specific example requires a square peg to change in width and depth when I imate (?) it to a rectangular hole. The receiving part has a number of rectangular holes so ideally I would not have unique parameters for each of the holes.
Any suggestions greatly received
Cadmanto
See if this thread helps you.
https://forums.autodesk.com/t5/inventor-forum/scaling-parts-when-placing-in-assembly/td-p/2935802
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! Conceptually, there is very limited associativity you can establish between an iPart member and another file (except the iPart factory). iPart/iAssembly was designed to create library components well defined by the author tables.
But, I think you might be able to do so with a custom iPart. Here is the workflow you may consider using.
1) Open the iPart factory file.
2) Create a unitless user parameter called ScaleFactor or something like that and set it to 1.
3) Use Direct Edit command -> Scale -> pick the part -> set Scale factor = ScaleFactor.
4) Edit author table and add ScaleFactor to the table.
5) Right-click on the column -> check Custom Parameter Column.
Now that, the iPart becomes custom iPart. When you place it in an assembly, you can enter a valid value for ScaleFactor and it should scale. You can also use iLogic rule to drive ScaleFactor within the assembly.
Would it work for you?
Many thanks!
Software Test Engineer
