Auto Inventor PDF to an AutoCad Drawing
Message 1 of 13
How do we go from Auto Inventor PDF to an AutoCad Drawing with your
product? DWG I believe. We need to be able to send a drawing to a
machine shop.
Thank you.
Replies (12)
Message 2 of 13
jtylerbc
Are you asking about converting an Inventor drawing to an AutoCAD DWG, or converting a PDF to a DWG?
Message 3 of 13
Yes
Kevin Hicks M Ed. ASE / MST
*Applied Engineering Program*
*“Electrifying” Aggies*
Automotive Technology / Career Prep I and II
Instructor/Coordinator
Poteet Personal Submersible Skills USA Project (P.P.S.P.) "Minion"
The Only Way We Go Is Down
Poteet High School
1100 School Drive
Poteet,Texas 78065
Office Phone: (830) 742-3521 ext. 1852
Cell Phone: (830) 708-9293
CONFIDENTIALITY NOTICE:
This email message, including all attachments, is for the sole use of the
intended recipient(s) and contains confidential student information.
Unauthorized use of disclosure is prohibited under the federal Family
Education Rights & Privacy Act (20 U.S.C. 1232g; 34 CFR Part 99)
*The information in this transmission may contain privileged and
confidential information and is intended only for the use of the person(s)
named above. If you are not the intended recipient, or an employee or
agent responsible for delivering this message to the intended recipient,
any review, dissemination, distribution or duplication of this
communication is strictly prohibited. If you are not the intended
recipient, please contact the sender immediately by reply email and destroy
all copies of the original message.*
Message 4 of 13
Yes we have several drawings that need converting so a machine shop can cut out our pieces.
Message 5 of 13
mcgyvr
Open the original idw file in Inventor (NOT THE PDF) and simply do a "save copy as" and select "Autocad dwg" as the file extension..
You do not convert the PDF to DWG (well you can but its not the right way to proceed)
Message 6 of 13
I have tried this. The problem is that these sheet metal parts when you do
a save as to a DWG file format generate AutoCAD drawing that when I try and
open in AutoCAD, I can see the paperspace but not the model space which is
what I need. I have tried the Export function in Inventor as well with no
luck. The problem is not generating Autodesk DWG files off PDFs, it is
generating DWG files off Inventor that have a model space and not just
paper space. The versions I am using are Autodesk Inventor Professional
version 2013 and Autodesk AutoCAD version 2013.
If they are willing to try and do the conversion for us, I can send
Autodesk Inventor files for the parts for the drawings we need converting.
Poteet High School
1100 School Drive
Poteet,Texas 78065
Message 7 of 13
mcgyvr
You simply need to adjust your options for saving autocad drawings..
Before pressing save hit the "options" button right next to it and modify the configuration..
See image..
Message 8 of 13
 Did not work
Message 9 of 13
blair
Of just so a File>Export>DXF
This will but your Inventor IDW file into a flat DXF file that your supplier can open.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 10 of 13
mcgyvr
@Anonymous wrote:
 Did not work
Then you didn't do something right..
It does work..
And please be a bit more specific.. What exactly didn't work? Did it still put all the geometry into paperspace?
Message 11 of 13
blair
Correction:
File > Export > Export to DWG > change the "Save as type" option from Inventor Drawing Files (*.dwg) to AutoCAD DWG Files (*.dwg). Then in the "Options..." box, make sure you set the "File Version" to a year that your machine shop can open.
Delta Tau Chi ΔΤΧ
Message 12 of 13
Mark.Lancaster
Side topic since @mcgyvr and @blair are assisting you..
Noticed your signature is related to a high school...
Are you using the free Autodesk educational software for your school and that was used to make this part?
If so is this machine shop something at school or are you contracting a machine shop elsewhere to make this part?
If this is an outside vendor are you paying them to make this design?
Mark Lancaster
Message 13 of 13
No we have designed the parts.
Based on you last post we were able to create what we needed.
You give a student an answer and you get him Passed the test.
You teach him to Read and you give him a Skill that he can use in his
occupation that will feed him for a Lifetime.
My Teacher Proverb
Poteet High School
1100 School Drive
Poteet,Texas 78065
