Auto highlights
Auto highlights
Message 1 of 9
Auto highlights
Stop auto highlights
Replies (8)
Message 2 of 9
Rob67ert
I guess you mean the highlighting when you hover over a part.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 3 of 9
mikaellarsson2070
Observer
Observer
I have the same issue.
I have tried every possible settings of the two checkboxes according to your image. For me the best option is to have both unchecked but
I still would like the highlight to just highlight after mouseclicking. As it is, the highlighting start after app. 2 seconds cursor howering.
Is this possible?
Micke
Message 4 of 9
Rob67ert
Hi there Mickle,
Welcome to this forum.
I don't understand the issue you have and what do you like.
Can you explain it a bit?
Robert
Message 5 of 9
mikaellarsson2070
Observer
Observer
When working in a assembly, part will highlight as soon as the mouse pointer is stationary for more than 2 seconds over it.
I would like the parts to just highlight when I mouscklick on it, not automatically after a certain time (2 sec) as it is now.
Micke
Message 6 of 9
Rob67ert
Try to change the selection under Tools, Application Settings
Robert
Message 7 of 9
mikaellarsson2070
Observer
Observer
I have tried to change the settings for the "Highlight" under Colors under Application Options under Tools. Is this what you mean?
This does not solve my problem.
Micke
Message 8 of 9
Rob67ert
Look at the picture i sent in my last post.
Robert
Message 9 of 9
mcgyvr
Micke
The only way to do that is to
#1-Uncheck "Enable Prehighlight" in tools..application options..Colors tab
#2-Change your select other delay in tools..application options..General tab to a high number (or 0 for "off")
But you will then have to right click to access "select other" as needed for other functionality or wait until whatever time you set for it has elapsed (or its totally off if set to 0) ..
