Inventor Forum
Auger flights flat pattern
4 REPLIES 4
1501 Views, 4 Replies
Hi all,
Need to make flat patterns for each flight. 8 flights total.
I have tryed doing them one by one but Inventor is telling me that "no bends found, nothint to compute" when i try the create flat pattern option. Also. I am not able to select any face when trying to define A-side.
Any ideas?
Inventor 2021
4 REPLIES 4
mikejones
Can you attached your attempt at it here
Mike
Autodesk Certified Professional
andrewdroth
Tags (1)
I was creating something similar and was able to use a surface loft between 2 3D sketches followed by a thicken of the surface. It did create a flat pattern accurate enough for us to laser and use. This technique might be in the link posted, I saw 3D sketches were mentioned there.
Hope this helps!
in reply to: andrewdroth
worked perfectly. tanks!
