JD- Thanks for taking the time to look at this.
Perhaps some explaining of my process will help.
This part is designed to mate with several off the shelf components. I get those from vendors, standard parts in 3D format. The parts are mathematically related to each other. I place them into an assembly in the proper spatial relationship accordingly.
There is an envelope size I must match. This part has to be no larger or smaller than a pre-determined size. Other than these pre-set definitions, there are standard shapes which must be used per vendor/industry standard- ingredients if you will. That's it, the rest is me being creative, not necessarily disciplined as a proper engineer or machinist need be.
The venturi type shape contains certain mathematical relationships. You can see that in the sketch with a floating cloud of points used as defining points for a spline. This flare is essential to the function of the finished assembly and therefore happens early in.
After that I hack my way right thru to the finished part. There are extra sketches and workplanes and all kinds of stuff that get in as a result of my hacking. Yes, hacking, that's how I do it. Most of those extra workplanes happened automatically and took no time to create.
Look- If I knew the finished size and shape of everything, and therefore didn't have to relate the separate parts, or project geometry back and forth, I too could create the thing with fewer features. But- the sheer number of features has no bearing in my hacking. There is no clock that says "Phil, you've got extra extrusions here, quit wasting your time." In the end, I get a part with the correct envelope size, the correct ingredients, and the correct special geometry that makes this thing so wonderful once it's a product. Along the way, I broke Inventor and all this mess started.
Consumer goods are a mix of standards, and creativity. Art. My artistic parts tend to be wilder, because I am chiefly concerned with a perfect appearance or rather, the result. The destination, not the path. All the constraints, or discipline in the world will not unlock that extra bit of creativity I get from flowing thru a part this way. IV gets a standing round of applause for letting me make these messes into things people look at and wish to purchase- bad process, extra sketches, too many workplanes later.
