Attempting to put an image file onto an .stl
Message 1 of 19
Well I think that's the idea, but I think it should be done as a Lossy Compression, as read in wikipedia. I don't think compressing it as a compressed file works, since Inventor needs to read the file not as a folder, I don't know I haven't tried. But even then your right about of how the capability of the 3D printer should be considered, because of the detail.
P.S I also posted it on quora Can inventor import images as lossy compression?
But I still don't know if it works this way
Replies (18)
Message 2 of 19
JDMather
OK, now we have a clean thread where we can address the problem.
I am afraid that you are completely and entirely confused about the nature of stl and image files.
Let's find out for sure and end all doubt.
This can easily be explained - but the best explanation would probably come from using your files directly.
Can you attach your stl and image files here (this is a yes or no question).
Place your files in a folder.
Right click on the folder and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
If the geometry is proprietary and confidential - then make up a dummy dataset that exhibits the same issue that you want to solve.
Message 3 of 19
JDMather
Where did you go?
This is an easy problem that should only take a few minutes to explain.
Message 4 of 19
Sorry I have to keep switch computers when when it gets to about 3:30 pm MDT, as I've got to go to university to be with kids. I'll have posted on monday, since I don't have access to inventor til then. However I can post as seperate files.
Message 5 of 19
JDMather
There are a large number of issues with your design technique.
Are you interested in learning to do this correctly, step-by-step?
Message 6 of 19
Oh right, is it too many lines? So yes I'd interested on knowing how to step by step, if otherwise I'll message you as I didn't realize that I can message you
I didn't expect to get reply back this soon
Again I'll have access to Inventor tomorrow morning
Message 7 of 19
JDMather
Are you a student?
Is this your personal computer?
iProperties indicates that you are using version 2015 Service Pack 0.
The first step is to download and install the 2 Service Packs and 5 Updates for 2015.
Let me know when you have completed this step for next instruction.
Message 8 of 19
Can I message you?
We can go back to replying as soon as I explain my background as a student.
Message 9 of 19
mcgyvr
Are you trying to "emboss" that image (at various heights) into the model so it will print with it..
Should be some "workarounds" here..
I think I've seen the inkscape recommendation in the past..
http://forums.autodesk.com/t5/inventor-general-discussion/how-to-emboss-or-extrude-a-logo-or-image/t...
I've seen other programs that can create a height map of an image based on darkness levels too that can be imported into Inventor..
Think this can do it..
https://memento.autodesk.com/features
blender seems to be able to do it too..
In the past with simple images I've just traced over the image in Autocad to get a closed profile too.. Works fine..
Message 10 of 19
JDMather
Start a new part file.
Turn on the Visibility of the Origin Center Point.
Sketch this 2-point center rectangle at the origin center point and dimension as shown.
Attach your *.ipt file here for next step.
Message 11 of 19
Ok Thanks, I'll try it out. Thanks for the links.
Message 12 of 19
OK thanks I'll see what I can do about
P.S I'll see if the IT staff can make that service pack installation
Message 13 of 19
OK so I made a few modifications to the top, as I looked up the size intended for it to fit a USB , it was 7 x 2 mm is now 12 x 4.5 mm, as I researched it on the internet although I thought it would be too big. So yes I'm new to inventor, so when you told me to attach the file, I was thinking I use Make Component, which the one below is an .iam file (Assembly file) although I still have the original. But I did what you told me what to do.
But I don't understand what you want me to do?
Message 14 of 19
JDMather
An Inventor part file is *.ipt
An Inventor assembly file is *.iam
When I ask you to attach your Inventor file here - simply attach the part or the assembly with parts.
Images are nothing more than pretty pictures.
If a pretty picture is worth a thousand words - an actual Inventor file might be worth a thousand pictures.
Message 15 of 19
I see the file format difference.
Message 16 of 19
JDMather
@Anonymous wrote:
So yes I'm new to inventor, .....
We need to take this design step-by-step as your design is pretty much a disaster.
I can walk you through the steps, but you have to follow the steps.
In post #10 I instructed you as the first step to create a 2-point center rectangle with the Origin Center Point in the middle of the 30x53 rectangle.  That is it.  Nothing more.
Go back and read Post #10 again.
Create this sketch and then attach your *.ipt file here.
Message 17 of 19
Sorry I took me while to do that, as I don't have anyone to show me how to auctually do it. So I looked on youtube and found how to do it, turns out it was actually a lot simpler then I thought.
I still couldn't get that dot on the centerline, even with the visibility turned on
Message 18 of 19
JDMather
Your latest attachment - you have gone too far.
My intention was to walk you through this step-by-step to do it correctly.
Your *.ipt file attachment should only have one sketch with one rectangle and two dimensions.
That is all.
See explicit instructions in Post #10 and #16.
Forget everything you have done previously.
Message 19 of 19
Ok so you want rectangle 1
