Attaching a Plate to a Frame - Stress Analysis
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to figure out how to attach a plate to a frame made from frame generator in Autodesk Inventor. So far, I have created a basic frame consisting of 3 rectangular tubular members from the frame generator and a plate by extruding a rectangular section that I sketched. I made the planes from the plate and the frame visible and used them to center the plate by constraining the respective planes to each other. I also constrained the plate face to the frame face. When I hit automatic connections, it is showing that I have 3 bonded connections as I would like to see. However, when I try and run a stress analysis and constrain the bottom vertical members and apply a force load to the plate face, I get warnings and it separates the parts into different components and adds a soft spring. I also tried to constrain the plate via bolted connections and also with welds and am getting similar errors.
I have attached the assembly files:
Any help would be greatly appreciated.
Best Regards,
Christian S.
