hey i want to make a hole in a plate that is 28x22 how to do that?
Solved by matroosoft. Go to Solution.
I would use the Hole command.
Can you attach your *.ipt file here?
Perhaps place a Sketch Point at the location where you would like your Hole feature.
I suppose you do want to make a slot?
Sketch Tab>Rectangle dropdown>Slot
Turn on your sound.
