assembly
assembly
Message 1 of 10
assembly
can anyone help, i have 3 parts i am trying to assemble and quiet new to this,
the curved sections go on the outside of the main panels, and the front panel goes on the flanges on the front
with a equal gap at top and bottom.
hopefully everything was drawn correct
thanks in advance
Replies (9)
Message 2 of 10
CCarreiras
HI!
Yopu have to attach here also the parts. The iam file doesn't bring the parts itself.
CCarreiras
Message 3 of 10
sorry, attached are the parts
required
Message 4 of 10
CCarreiras
I don't understand well how you want to place the parts, place a picture, or explain better.
anyway...... here's an example how you can apply constrains...
CCarreiras
Message 5 of 10
hi thanks for that, im struggling with this though
attached are the parts  and also the end detail
i need the front panel central as you did before and also the ends going around the semi circle and sitting flush
hopefully if someone can help i will retrace the steps and learn that way
cheers
Message 6 of 10
mcgyvr
The parts aren't drawing correctly .. Quite a few errors/issues actually (casing ends too long,etc..missing dimensions/under constrained sketches)
BUT..
Here are 2 huge tips that will help with Inventor
#1-Center all parts around the origin planes (center point).. (use the born technique)..
http://blogs.rand.com/files/the-born-technique.pdf
#2-never leave a sketch not fully constrained..
There are many ways to "constrain" this but without me putting any real thought into it I did this..
and sorry about the stupidity on my part from about 10 to 25 seconds.. I wasn't thinking and had it in "insert" vs "mate" constraint option.... ignore that..
But here is 1 way of many..
Message 7 of 10
hi,
could you tell me what view you were using on this video, as seemed alot easier than mine
cheers
Message 8 of 10
mcgyvr
@Anonymous wrote:
hi,
cheers
I'm using a 3d connexion device.. (I have a space pilot but a space navigator is all one really needs)
I assume thats what you are talking about and why I can flip/spin/zoom/rotate,etc... fast
They are the best thing since sliced bread for 3d modeling..
Takes a few days to get used to but once you do its amazing..
I won't work without one.. Easily worth the $100 just in time saved alone..
Message 9 of 10
johnsonshiue
Hi! There is a type of mate less known to the user. It is called cylindrical face mate. In Mate constraint dialog, you can hover to a cylindrical face -> select other -> the cylindrical face will be highlighted -> select another cylindrical face.
Does it work for you?
Thanks!
Software Test Engineer
Message 10 of 10
on my next part, which ive attached
when i lay it flat the curve of the folded rad sticks out the side of flat blank, how can i make this straight?
cheers
