In my assembly, the densit in the physical properties isn't showing the correct density. Every part is aluminum-6061 and i have checked in each part. The density reads 2.710 g/cm^3. But then when i go to the overall assembly properties it will read something different. I tried looking at some of the different subasseblies, and each one seems to read some random density. I am trying to figure out the CG of this overll asssembly, but I am not sure if it is correct because the density is wrong.
Now, i know that whether your density is 1 or 100 the cg will still be the same, so i may be okay, but i can't help but worry, thinking that maybe it is averaging other made up densities (i dont think that is what it is doing).
A few other notes:
-parts are mostly iparts
-took a few parts and threw them in a new assembly and the density read what it should.
Any help would be appreciated.
Thanks!
