I working on an assembly that became "slow" all of a sudden. It's only this one file, when adding or modifyiing constraints it can take a several minutes to figure it out. Also creating new parts is quite slow. I have disable quick file open.
The files are stored locally on the computer, the is 218 total occurances and 89 open documents in the session. Again, it's only this one assembly file, all other assembly files function fine. CPU usage is 12% when it "freezes" up and physical is at 58%. The model is not slow in regards to changing views orbiting or opening.
Any ideas?
Solved by porter-jeff. Go to Solution.
I should add there are no sick or conflicting constraints in the assembly
Hi! It sounds like there is something not working right in the particular assembly. Could you share the files with us? I can set up a secure account for you to upload. Please send me an email directly (johnson.shiue@autodesk.com).
Many thanks!
