Assembly Pattern
Assembly Pattern
Assembly Pattern
When in an assembly how do i pattern along a sketch. I have a NBW that i want to follow a sketch which has the holes already ion place?
What method would i use as there seems no option for curve driven pattern with Rectangle Tool
Fred
JDMather
Attach the *.ipt file here that has the holes.
Did you use a Curve Driven Pattern for the Holes?
Post#8
http://forums.autodesk.com/t5/inventor-general-discussion/skillsusa-document-now-on-screencast/m-p/5...
these are the 2 files. These are 2013 files
Yes - curve driven
Fred
ok i will also check out post-8
thanks
JDMather
@Anonymous wrote:
Yes - curve driven
Fred
Fantastic - you did it the right way.
You don't need a sketch in the assembly - you will pick the pattern from the part file to follow that pattern.
There is a little bit of a hidden trick.  I think back in 2013 you had to make the part features visible in the assembly.
Yes i found it by trial/error and it worked.I than tried it without the sketches and it still worked
I got it to work in the assembly mode. I will try the modelling view now
Thanks again
Fred
