Assembly/Part Half-Section highlighting
wrw0007
Message 1 of 13
wrw0007
I was browsing another forum and came upon a question that I never really thought about myself as it doesn't posee any issues for me. He is a new user coming from another program and I pointed him towards this forum.
When you section an assembly or part you are left with a display of (usually) half of that part. If you hover over it, you see the prehighlight that shows the entire part, half as active and half as "inactive" or as a "ghost" as he put it.
I say "inactive" in quotes because the software doesn't see this as an inactive part.
His question was whether this "ghost" could be toggled on or off.
Digging through the (Tools>Application Options>Display) and similar places I could not find an option for this. The closest I found was (Tools>Application Options>Color>Disable PreHighlight). This is an easy cut and dry workaround for when you need to present a clean model to a client or coworker, but is there a formal solution for this? I have used other programs that have this setting, but they also handle assembly sections in a different fashion.
Thoughts?
Replies (12)
Message 2 of 13
Message 3 of 13
wrw0007
That's not what we are trying to achieve, but I appreciate the response and reference.
Message 4 of 13
I can't say I really understand the problem.
Message 5 of 13
wrw0007
No problem.
I have attached 2 images showing a pipe assembly that has been half sectioned.
The first image shows the assembly without hovering over the pipe.
The second image shows the assembly while I am hovering over the pipe.
When hovering over it, the silhouette of the removed (graphically) pipe shows up. (circled in red)
Is there a setting to remove that silhouette?
Message 6 of 13
Message 7 of 13
wrw0007
I have. And it almost works. But leaves the outline of the part.
Message 8 of 13
admaiora
Hi Wrw,
sorry, you can't do it.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 9 of 13
wrw0007
So it seems. Not a big deal. it doesn't impede workflow... Maybe an idea for the idea station for future versions?
Message 10 of 13
Do you have enable PreHighlight uncheck also.
I have both unchecked and I get no highlight at all unless I click on the part.
I have been working in an assembly, I just tried this in a part file, and it does not seem to work the same.
Message 11 of 13
wrw0007
As mentioned in the original post, I have done this. It does work as a workaround, but this isn't section specific and disables the highlighting of every part all the time. Not only when a section occurs.
For another route of action, is there a way to set up a hotkey/key combonation to toggle those two options? This would be a much more viable solution.
Thank you for the responses.
Message 12 of 13
I have deselected both "enable prehighlight" and "enable enanced highlighting" and am still getting highlight on hover.  I only want it to highlight if I select it.
I am trying to constrain two parts and can't see the edges of what I need because the highlight is too dark, not to mention incredibly annoying.
Please tell me how to shut it off.  I am working on 2011.
Message 13 of 13
William.LamJZ983
Unchecking both of those "enable"s did the trick. Thank you! That resolved the very frustrating feature.
