Assembly orientation changed
Hi All,
My Assembly has changed its original view (front/side/top).
How do I revert the changes so that my sides are direct side on facing?
Xun.Zhang
Hello @Anonymous,
It seems camera change in your side.
Don't worry, find a plane and set look at that plane, right click in the viewcube and set as Front, after that, click viewcube rotate and set Left. Top as the same way.
or you can simply reset the view (Front, left or Top) in context menu and switch back.
Hope it helps!
Xun
jhackney1972
You are indicating that your view is not relating to the View Cube faces.  Take a look at the screencast and you will see how to fix this.  The solution shown does not correct the relationship of the model to the assembly origin planes.  This is accomplished by un-grounding all parts and then constraining it to the origin planes then grounding at least one component.
John Hackney, Retired
