assembly not updating directly
Dear,
So I made this assembly from sheet metal models. The problem is when updating the parameters I have to press run all rules two times to get these parameters the way I want is there a way to get it right without pressing run all rules. The problem I think is in the first rule I link the parameters to other parameters from the models itself. In the second rule I use the linked parameters to offset the models. So The linked parameters should update before going to the second rule.
rule 1:
SyntaxEditor Code Snippet
Parameter("dubbele buiging kleine compact L1:1", "Thickness")=dikte
Parameter("dubbele buiging kleine compact L2:1", "Thickness")=dikte
Parameter("dubbele buiging kleine compact L3:1", "Thickness")=dikte
Parameter("dubbele buiging kleine compact N:1", "Thickness")=dikte
Parameter("dubbele buiging kleine compact L1:1", "zaagdikte")=zaagdikte
Parameter("dubbele buiging kleine compact L2:1", "zaagdikte")=zaagdikte
Parameter("dubbele buiging kleine compact L3:1", "zaagdikte")=zaagdikte
Parameter("dubbele buiging kleine compact N:1", "zaagdikte")=zaagdikte
Parameter("dubbele buiging kleine compact L1:1", "stuks")=stuks
Parameter("dubbele buiging kleine compact L2:1", "stuks")=stuks
Parameter("dubbele buiging kleine compact L3:1", "stuks")=stuks
Parameter("dubbele buiging kleine compact N:1", "stuks")=stuks
Parameter("dubbele buiging kleine compact L1:1", "EersteBuiging")=EersteBuiging
Parameter("dubbele buiging kleine compact L2:1", "EersteBuiging")=EersteBuiging
Parameter("dubbele buiging kleine compact L3:1", "EersteBuiging")=EersteBuiging
Parameter("dubbele buiging kleine compact N:1", "EersteBuiging")=EersteBuiging
Parameter("dubbele buiging kleine compact L1:1", "Hoogte")=HoogteL1
Parameter("dubbele buiging kleine compact L2:1", "Hoogte")=HoogteL2
Parameter("dubbele buiging kleine compact L3:1", "Hoogte")=HoogteL3
Parameter("dubbele buiging kleine compact N:1", "Hoogte")=HoogteN
Parameter("dubbele buiging kleine compact L1:1", "hoek")=HoekL1
Parameter("dubbele buiging kleine compact L2:1", "hoek")=HoekL2
Parameter("dubbele buiging kleine compact L3:1", "hoek")=HoekL3
Parameter("dubbele buiging kleine compact N:1", "hoek")=HoekN
Parameter("dubbele buiging kleine compact L1:1", "dubbelgat2x")=dubbelgat2x
Parameter("dubbele buiging kleine compact L2:1", "dubbelgat2x")=dubbelgat2x
Parameter("dubbele buiging kleine compact L3:1", "dubbelgat2x")=dubbelgat2x
Parameter("dubbele buiging kleine compact N:1", "dubbelgat2x")=dubbelgat2x
Parameter("dubbele buiging kleine compact L1:1", "Lengte")=lengte
Parameter("dubbele buiging kleine compact L2:1", "Lengte")=lengte
Parameter("dubbele buiging kleine compact L3:1", "Lengte")=lengte
Parameter("dubbele buiging kleine compact N:1", "Lengte")=lengte
Parameter("dubbele buiging kleine compact L1:1", "offsetgat2metkant")=offsetgat2metkant
Parameter("dubbele buiging kleine compact L2:1", "offsetgat2metkant")=offsetgat2metkant
Parameter("dubbele buiging kleine compact L3:1", "offsetgat2metkant")=offsetgat2metkant
Parameter("dubbele buiging kleine compact N:1", "offsetgat2metkant")=offsetgat2metkant
Parameter("dubbele buiging kleine compact L1:1", "gat1") = gat1
Parameter("dubbele buiging kleine compact L2:1", "gat1") = gat1
Parameter("dubbele buiging kleine compact L3:1", "gat1") = gat1
Parameter("dubbele buiging kleine compact N:1", "gat1") = gat1
Parameter("dubbele buiging kleine compact L1:1", "gat2") = gat2
Parameter("dubbele buiging kleine compact L2:1", "gat2") = gat2
Parameter("dubbele buiging kleine compact L3:1", "gat2") = gat2
Parameter("dubbele buiging kleine compact N:1", "gat2") = gat2
 rule2:
d25=Parameter("dubbele buiging kleine compact L1:1", "LengteRechteLat")*stuks+zaagdikte*stuks
d19=Parameter("dubbele buiging kleine compact L2:1", "LengteRechteLat")*stuks+zaagdikte*stuks
d22=Parameter("dubbele buiging kleine compact L3:1", "LengteRechteLat")*stuks+zaagdikte*stuks
 Already thanks for the help,
Sebert Verbeek
admaiora
i think thant using these snippets correctly in your rule you can solve it.
You can run other rule from inside a rule (using the rule name correctly)
You can update your model ( equivalent to click the orange bolt update)
You can make the rule autoactivate when something happen (event triggers)
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Thanks for the answer.
It doesn't seem to work as it should be. I still somehow have to press run all rules 2 times.
