Assembly noob
Assembly noob
102169026
Assembly noob
102169026
hello,
new to assemblies. im attempting to push the lid in then rotate 90deg then push down again like the parts would work in real, however unable to line up the slot then rotate it. apologies, this is probably a simple task ...
thanks cm
JDMather
@102169026
An iam file is simply a list of instructions on how the parts (*.ipt files) are put together.
You must include the part files.
oh sorry. here they are
johnsonshiue
Hi! Please also attach razor1.ipt and razor2.ipt here.
Many thanks!
Software Test Engineer
oops sorry.
johnsonshiue
Hi! Many thanks for sharing the additional files! Now I understand what you are trying to do. The two parts are not yet constrained. As a result, the razor2:1 is free to move, while razor1:1 is grounded. You need to add an Insert constraint between two circular edges. Then add an angular constraint so that the razor2:1 is at the desirable angle. The animation can be created using Inventor Studio via animating constraints workflow. Please let us know if more information is needed.
Thanks again!
thank you. i shall try this now 🙂
