Assembly Length in BOM
avaya2012
avaya2012
I am using Inventor Pro 2018.  We are upgrading to 2019 in a few weeks but that should not affect anything.  I am creating a drawing with a BOM and want to show a length of piano hinge assembly.  The piano hinge is made up of two parts so it can actually hinge in the assembly.  I cannot get the length of it to show up in the BOM without overriding it in the BOM itself.
I tried exporting the length from one of the parts then linking it in as a parameter in the assembly to no avail.  My other idea was to put a dummy sketch in the assembly and use that parameter.  That seems to work at first but it reverts back to Qty: each.  I will go into the Document Settings - Bill of Materials - find my length parameter - click OK - click Apply.  It all looks good until I go back into the Document settings and it is back to a quantity of Each.  The BOM structure is set to Purchased.  It doesn't seem to make a difference if I change it to Inseperable.
This seems like it would be something fairly straight forward.  Am I missing something or is this not possible?
CWW
jletcher
In the assembly Parameters link the part with the exported dimension. And then export it from there for drawing.
avaya2012
I did that as you can see in the first picture.  The second picture is where I change the BOM base quantity.  The third picture is when I go right back into the Document Settings.  It reverts back to Each.  I hope this isn't to cluttered and makes sense.
jletcher
You don't have it linked from the model .ipt look at my picture.
My link is in the assembly parameters.. yours is not a link.
jletcher
if you are in 2018 upload the iam and the parts
jletcher
Video for you
avaya2012
I have it linked correctly now.  I can see my value in the Custom tab in iProperties.  Is there another step?  I can find and select my length in the Bill of Materials tab in Document settings.  It just reverts back to "each" each time.  Do I need to do anything special in the drawing.
I am leaving for the day shortly so I will get back at this Monday.
