Assembly home view
Assembly home view
jeyaar
Message 1 of 9
Assembly home view
jeyaar
I am struggling to return my home view which zooms in the whole assemlby and extends all over the screen. Then i click home view the assembly dissapears almost just one dot on screen.
I tried to find any parts "flown away", but nothing is found.
Please advise how to return proper home screen which extend all over the screen
Many thanks!
Replies (8)
Message 2 of 9
johan.degreef
Did you bring in an Autocad -drawing somewhere?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Message 3 of 9
aaronbreaux
First thing I would do is see if you have one item in your assembly set to "ground", if not there is a good chance your assembly moved away from the origin which could be causing your issue. It is a very good habit to get into when inserting your first item in your assembly to right click and select "Place Grounded at Origin"
If you upload your assembly here we can better troubleshoot your issue
Message 4 of 9
jeyaar
Yes it contains, but I switched off the visibility, but the home view result was the same
Message 5 of 9
jeyaar
I have mated the main parts to base planes. Which concerns others I have mated these on main parts. I do not use grounding parts option.
The assembly is really big - 4000 parts.
May be one can advise some methology find the solution
Message 6 of 9
jeyaar
I am trying to find "flown away in space" by dragging all over the empty space. if there are any parts then the option show in model tree can be clicked. I have tried to find these parts at every angle, but no success
Message 7 of 9
johan.degreef
Then I would look at the autocad drawing for turned off layer displaying some lines far away. Try to do a zoom extents there.
Switching off it's visibility in inventor won't be enough
Message 8 of 9
CStilesCARE
If you want to try and narrow down the culprit, try creating a new View Representation in your assembly and hide EVERYTHING. Then, choose a single part/component that you're fairly sure isn't the problem and make it visible again (making sure to set it's View Rep appropriately if necessary), and click the home view to see if it zooms in as it should.
If the home view zooms properly, start making more components visible (and with proper view reps) one or two at a time and clicking the Home view until you find one that throws the zoom way out. That component has something in it that's causing trouble!
Open up the problem component and fix any issues if possible, then go back to your main assembly and continue turning on components and checking home view zoom until everything is turned on and zoom works (or you are stuck with yucky view, but at least know the source).
When checking components for issues, ensure that they don't have any parts or components way off somewhere and that there are no sketches or work features which are very large compared to the assembly (this component will likely have the same "Home View" zoom issue).
When fixing sketches, check for things like orphaned points or center points on very large radius curves.
Orphaned points can often just be deleted (these are sometimes easier to find if your sketch is not fully constrained and you turn on the "Show All Degrees of Freedom" option while in the sketch).
For large radius curves, sometimes you can substitute in straight lines or 3-point interpolation splines (points at start, middle, and end of curve/arc) to get rid of the centers.
If you can't change some curves to remove centers, you may be able to copy the geometry into AutoCAD, convert it into splines, then copy/paste back into Inventor. There may be times where you're just stuck with those centers though.
For fixing work planes (or axes), check to see if "Auto Resize" is on or off. If "off", then try turning it on to see if it gets smaller. If not (or if it was already "on), then it's likely sizing to match a giant sketch (see fixing sketches above).
To force them smaller, turn off "auto resize" and then manually resize/move by clicking and dragging on the corners and/or edges (the mouse cursor should change when you're over the right area).
Message 9 of 9
SBix26
Most efficient means to identify the rogue component is to make half the components invisible, try Zoom All.  If that doesn't fill the screen, try making half of those components invisible and try again (otherwise, switch to the other half).  You get the idea, just keep narrowing it down by half, and you should soon figure out which component is the problem.
Sam B
Inventor Pro 2023.1.1 | Windows 10 Home 21H2
