Inventor Forum
Assembly ->>> Limits+ insert constrain
18 REPLIES 18
Message 1 of 19
648 Views, 18 Replies
Hi!
I am fighting with hydro cylinders.
I have outer part numbered 11
and inner part 12.
I need to complete 2 tasks:
  • 1)))To insert 12 into 11
Q: Sometimes  I can see center line and sometimes not, so I don’t understand the strategy for constraining these parts
  • 2))))To set limits, so that inner part can’t go out from outer part.
Q: This assembly comes from the tutorial. In the tutorial it works, but I am failing to do that
Here is the link for file
https://www.dropbox.com/s/5rargf8scranffv/test%20zipped.zip?dl=0
Thank you
18 REPLIES 18
Message 2 of 19
Curtis_Waguespack
Hi s.shivaprem,
Here's a quick video.
I hope this helps.
Curtis
Message 3 of 19
tdant
And here's the result, in case you need it: https://www.dropbox.com/s/dpqgyztvszjxgxu/test%20zipped.zip?dl=0
Message 4 of 19
salariua
@Anonymous
You should never use insert or axis mate on cylinders but that's my personal experience.
I would mate/flush origin planes (if they are on center) and have 2 Positional Representations. One flexible so you can set this cylinder assembly as flexible and simulate movement from higher up and the other constrained and you control the stroke with iLogic (best option really) and slides in forms.
Insert and flexible don't play nice and axis mate will allow rod spinning which is not what you're after, unless this is a rotating actuator.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 5 of 19
mcgyvr
in reply to: salariua
@salariua wrote:
@Anonymous
You certainly can just use an insert (with limits) and a mate (or angle) on a plane to prevent rotation.. You only need 2 constraints that way vs needing 3 if only using mates.. That removes the extra degree of freedom that can cause flexible to behave a little weird..
Message 6 of 19
salariua
in reply to: mcgyvr
It's just a personal preference on my end. I don't like inserts because I would be referencing an edge which can disappear with chamfer or fillet and then I get constraint errors.
This assembly is actually a big iLogic assembly which changes parts depending on the cylinder type, mounting, etc. so using anything else than origin planes for constraining will break functionality.
Adrian S.
blog.ads-sol.com
Message 7 of 19
Thanks for all yours replies!
I will try all your approaches and will let you know how it works.
Thank you!
Message 8 of 19
in reply to: Curtis_Waguespack
@Curtis_Waguespack, hi!
I want  to thank you for your approach, but for some reason my silver part is frozen and
I can't figure out the source of this problem
Thank you
the file is here https://www.dropbox.com/s/rteqi8y0lp6licn/Assembly%20H2%20-%20frozen%20%20zipped.zip?dl=0
Message 9 of 19
@salariua, hi!
Thank you for your help, but I understand nothing.
I don't understand the text.
and the actions on video are to quick, so I can't follow them.
Here is the link for the original files:
https://www.dropbox.com/s/kbmu4mus8dzfkls/assembly%20H2%20%20original.zip?dl=0
It would be great if you could create screen cast on my assembly,
since  I don't understand what is happening in assembly you used as an example.
Thank you in advance!
Message 10 of 19
johnsonshiue
Hi! This should a pretty simple task using Insert constraint. Just pick one circular edge from each part and set the Max and Min limits. Have you gone through Inventor tutorials, particularly the assembly portion?
Many thanks!
Software Test Engineer
Message 11 of 19
JDMather
You are more likely to get Autodesk Screencast solution if you attach your assembly directly here rather than to 3rd party dropbox.
Message 12 of 19
in reply to: johnsonshiue
Message 13 of 19
in reply to: JDMather
here is the file for the frozen assembly
Message 14 of 19
and here is the file for the original assembly
Message 15 of 19
JDMather
These files are not needed.
I do not see any Limits set on your Insert constraint?
Message 16 of 19
JDMather
Note the file size of my attached zipped folder of your parts and assembly.
I skipped over this in the video - but note that you need to expand the dialog box to get access to the Limits.
This is covered in any typical book for learning Autodesk Inventor.
Message 17 of 19
@JDMather!
I like your explanations!
Simple and very useful!
Thanks!
Message 18 of 19
@salariua!
I also want to learn your approach with mate.
It would be great if you could create screen cast explaining your way by using my cylinders.
Message 19 of 19
JDMather
@Anonymous wrote:
@JDMather!
Thanks!
Curtis demonstrated the same thing 3 days earlier in this thread.
It is important to experiment without being given each explicit step and observe the results you get through trial-and-error.
